Old 12-02-2007, 03:20 PM
Default Gessford machine
Jimmymac Look on Gessford machine site. I think he sells a whole kit for FE motor. You better check for hood clearance and room to fit it. You may need a twin paxton hood to clear the blower. It will not fit under the stock hood of an ERA without the scoop. You will need oil pressure and return lines for the blower. You can tee into the sendor or line for the pressure gauge. The return went into the timing cover. Used #8 return line. #4 perssure line. There is an oriface to control the oil spraying into the case. You need to think about an intercooler or water injection kit. Water is easier with the mister systems. Go with Vee belt and not clogs. Vee belt gives and slips, clogs don't. I stripped 2 belts and gave up. I will try again at a later time now that I have a paxton hood for my car. If you want to talk about this, call me Jimmy in the evening est time after 8:00pm 732-254-3536 Rick L.
