Old 12-02-2007, 07:11 PM
SantaFe66 SantaFe66 is offline
Cobra Make, Engine: Cardiac, 428 FE
You can save some money over the Battery Tender by going to Sears and buying their battery maintainer. I've used it successfully on my Optima battery for the last 2 winters (get's pretty cold, but dry, here). I drain the radiator and put in fresh A/F with corrosion inhibitor and a bottle of Redline Waterwetter. Of course, I have added Sta-Bil to the gasoline and ran it a bit to get it through the fuel system.
After all that, I let it sit for the winter. Seems to work OK for me.
I also use an Accumate charger/maintainer for my motorcycle and have found it to be outstanding. Here's a link for it:
http://www.hotrodssuperstore.com/acautcharand.html
Shop around for the Accumate as the price varies and it usually is about the same price as a Battery Tender, but can be found cheaper. These maintainers prevent sulfation in the battery which will short cells out if the battery isn't on a maintainer. Well worth the money and hassle come spring.
Paul
