Old 12-02-2007, 08:40 PM
stephen low's Avatar
stephen low stephen low is offline
Well done Al.
If all goes well tomorrow, I will be registered - hence the rapid response to fix my buggered pump.
Admittedly the new pump is faintly making the same sort of sounds which is a worry.
Is there anything critical about the style of mounting on these pumps? I'd been given a fabricated strap that contacts over 180 degrees around the pump but have been bolting to a flat plate. Would this perhaps create internal pressure to cause rapid bearing decline?
I have seen the fabricated alloy holders which encircle the pump hence an even pressure.
Can anyone comment on this point?
slowy
