Old 12-03-2007, 06:02 AM
Default Intercooling of some kind
mhacars If you are running 6 psi of boost, run super gas and retard the timing 2 degrees for every pound of boost, I would say you are OK. E-85 gas you might get away with. If you put 10-15 grand in a blower motor, even with the best parts, what another $400.00 for the waterinjection. You can hook a boost switch up to turn the system on and off with boost only. Sorry I have seen to many motors blowup from detention. I custom modifiled a Vortech intercooler for my car and changed both inlet and outlet openings to fit in my car. The weight was 20 lbs more than if I went with water injection. The only thing is to refill the tank. You check the oil for the motor and check the tank. 2 minute job. Gessford brakets are built for FE motors. You might have to custom the other brackets for P/S and A/C, The setup I saw works with Alt,water pump, and crank. With the box setup for a single carb, it might fit under hook. The side by side with 2 paxtons will not. The other problem is room for an airfilter. Rick Lake Ps I used screen on my setup no room for filter. The other thing was hot air from the motor. I used foot box hose from r/s to go to blower. Blowers get heat soaked and make enough hot air.
