Old 12-03-2007, 08:16 AM
Jon Miller Jon Miller is offline
Club Cobra Member
Cobra Make, Engine: Former Everett-Morrison,428SCJ
Hi Pri,
You can get the gasket material from Summit, and cut them yourself. The stuff is not easy to cut. I drilled through it with a wood bit, and then finshed it up with a sanding drum on a Dremel. Clamp the gasket to the sidepipe flange and the pipes will act as a guide.......you may not want to do this if your pipes are coated(mine are stainless).
-Jon
