Old 12-03-2007, 07:53 PM
Dwight's Avatar
Dwight Dwight is offline
Smile sidepipe gaskets
I blew out Mr Gasket gaskets, Hi-Temp sealants, everything I tried, I blew out. I bought a sheet of laminated aluminum (.048" .003" 9574K32 $56.07). I used a hamner to outline the gasket, hole cutters to cut the large and small holes and tin cutters to cut the outside edge of the gaskets. One year, 5000 miles and no leaks.
http://www.mcmaster.com/
Dwight
I could sell you enough material to do two gaskets if you want. Just give me to size you need. 6" x 6" $8 a pair plus a little shippping.
Thickness
.006" | .008" | .010" | .016" | .020" | .021" | .032" | .033" | .048" | .062" | .094" | .124" | 1/8" | 3/16" | 1/4" | .063"
Laminated Layer Thickness
.002" | .003"
These 19 products match your selections
Thickness Laminated Layer Thickness Each
.006" .002" 9574K11 $17.13
.008" .002" 9574K12 18.34
.010" .002" 9574K13 21.07
.016" .002" 9574K14 23.44
.016" .003" 9574K25 21.73
.020" .002" 9574K15 37.23
.021" .003" 9574K27 34.84
.032" .002" 9574K16 43.51
.033" .003" 9574K31 38.69
.048" .002" 9574K17 48.37
.048" .003" 9574K32 56.07
.062" .002" 9574K18 66.82
.094" .002" 9574K19 96.51
.094" .003" 9574K34 99.37
.124" .002" 9574K21 107.42
1/8" .003" 9574K35 132.64
3/16" .003" 9574K61 178.60
1/4" .003" 9574K62 259.06
.063" .003" 9574K33 74.15
