Greg
I had a very similar problem 2 years ago. Mine would run fine for 10 or 15 minutes then either begin to miss really badly then die completely, or else it would just die like yours does. If I waited a couple of minutes, it would fire up and run perfectly but 10 minutes later it would die again. I changed the coil, the pickup coil and the MSD box, but I always had the same problem.
I remembered that I had pulled the dash out of the car the previous winter so I figured that maybe something when wrong when I re-installed the dash. I removed the dash and sure enough, a 10 wire connector was not properly connected. The connector pin for the wire from the ignition switch to the MSD box was probably getting hot after the engine ran for a while and the contact would break due to the heat. After sitting for just a minute or two, it would cool down so a proper connection would be re-established and the engine would run fine.
One way to check to see if this could be the type of problem you are having would be to completely bipass the normal ignition circuit, I guess by running a wire from the + battery terminal to the small red wire on the MSD box. You would probably also have to leave the key in the normal "run" position to make your other stuff work. Maybe some of the other guys that know more about the electrical and electronic stuff can tell you exactly how to do this.
Wayne
Don't get caught dead, sitting on your seat belt.
