Old 01-14-2008, 10:24 AM
dawger dawger is offline
Registered User
Cobra Make, Engine: Hurricane
Greg-
Someone mentioned checking the ignition switch as well. I had a very similar issue in my 69 Mustang. The car would shut off as if someone turned the key off, then it would start back up as fast as you could turn the key to off and back on, sometimes just turning it to start would fire it back up, sometimes depending on temperature it might take a few minutes to restart. Come to find out after frustration set in, the contacts on the back of the switch were loose and causing bad current exchanges getting hot and sutting the car off. Might want to investigate there as well.
Cobra some day
Dawger-
