Old 01-15-2008, 09:15 PM
GlynMeek's Avatar
GlynMeek GlynMeek is offline
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Interesting that you say "the fan never shut off". It should never have switched on at those temperatures. Try disconnecting the fan and letting the engine run and see if THAT gets the temperature up.
You never did say if your fan is connected to a thermal sensor/switch of some kind, or if it just comes on with ignition power!!!! (If so, then you should change to either a manual switch or (preferably) a thermal switch for that fan!)
Glyn
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
