Thread: Ford rear end
Old 01-17-2008, 06:14 AM
Philm's Avatar
Philm Philm is offline
Default Sounds Like a plan.
Hey Mike,
I am actually going to re do the whole rear, I am waiting anxiously to see how your rear end will turn out as I will do the same.
This doesn't look like a complicated install, achieveable with the body on.
If only I did do this when the body was off getting painted.
Mike, if your look at the ford racing catalouge they have may options for the differentals, like Auburn, traction lock..... do you know what the differences are?
Also with these can you use the same flange type on the pinion as we have now.
Phil
