Old 01-17-2008, 10:51 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
If you are running double springs pull the inside spring out if not, then don't worry about it. Keep your RPM's at 2000 for 15-20 mins at least. Shut your engine off, change the oil and put in a new filter (check for any debris in the oil and also your filter). Put in more oil and a filter and start it back up and let it run at about 1000 RPM for a little longer. Remove your filter and cut it apart and check for any gold or copper flakes. Put on a new filter again and top off the oil.
Don't worry about anything you find in your oil that isn't metallic or shinney. It probably would not be a bad idea to pick up some of the GM solid lifter cam breakin addative ($10/pint) to run in your car for the first 300-400 miles.
Clois
"Let's roll"
"Be part of Something Good
