Old 09-04-2001, 11:05 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Jack,
I'm thinking valvesprings more than anything else, particularly with a hydraulic roller and mix & match parts. The roller lifters tend to be heavier than regular hydraulic lifters, so a stiffer spring is needed. Talk to the tech guys at Crane & Comp and see which spring you should be using.
Almost any aftermarket performance cam, even the milder grinds, should be able to rev to 6000 - 6200.
