Old 01-18-2008, 04:22 AM
sideoiler10 sideoiler10 is offline
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Default Engine Breakin
I don't intend to hi-jack your thread, but I have some information about the zinc issue in today'a oils.
Has anyone heard of "ZDDPlus"? Accjording to information provided by the manufacturer, it contains a much higher level of zinc than the old GM EOS product. I emailed the manufaturer and he provided quite a bit of information.
I have posted his email below. Check out the website. For about 10 bucks a bottle I think it would be a bargain. I apologize for the length of this post, but the zinc issue is important to those of us who prefer the solid flat tappet sound of an FE.
Autosound 2000 Inc. 2557 Faucette Lane, Burlington, NC 27215 www.zddplus.com (336)570-0341 September 18, 2007 Who is Autosound 2000? Autosound 2000 is a company formed by classic car enthusiasts to meet the needs of classic car aficionados. We have seen that the automotive industry in general is changing in response to the environmental and financial pressures of today, with little concern for the classic car industry. We are engineers and automotive technicians by trade, and bring many years of problem solving experience to the task of keeping our classic cars operational and running better than new. We hope that one of the solutions we have designed for our own use will meet your needs as well. We have developed ZddPlus + tm to address the needs of classic car owners for an oil that will meet the specifications of the original oil for which their engines were designed. Why do we need ZddPlus + tm ? As part of an effort to reduce vehicle emissions, the U.S. EPA offers vehicle manufacturers “credits” for early implementation as well as penalties for violation of emission reduction standards. The EPA’s program called for 100,000-mile catalytic converter life by 2004, 120,000 miles by 2007, and 150,000 miles by 2009. To achieve these goals, automotive manufacturers have pressured their oil suppliers to remove substances from motor oils that would shorten the service life, including the proven EP (extreme pressure) additive ZDDP (zinc dialkyldithiophosphate). Zinc and phosphorus from the ZDDP can be present in small amounts in the exhaust gas of an engine depending on the amount of oil which is consumed in combustion. These elements can coat the catalyst reducing the amount of catalyst exposed to the exhaust gases, ultimately increasing emissions at the tailpipe. As a result of the EPA mandate, the ZDDP level in engine oils has been declining since the mid-1990s, roughly coinciding with the implementation of OBDII. ZDDP has been an important additive to engine oils for over 70 years, and has an excellent track record at protecting the sliding metal-to-metal cam lifter interface. Historically, ZDDP has been added to oils in amounts resulting in approximately 0.15% phosphorus, and 0.18% zinc. ZDDP protects by creating a film on cams and flat lifter contact points in response to the extreme pressure and heat at the contact point. The film of zinc and phosphorus compounds provides a sacrificial wear surface protecting the base metal of the cam and lifter from wear. In the course of normal service, this conversion of ZDDP to zinc and phosphorus compounds depletes the ZDDP level in the oil. Studies show that depending on the specific engine and severity of duty, after 2000-4000 miles of operation, the level of ZDDP can drop below that considered adequate to provide wear protection to the cam and lifters.
If you are currently putting mileage on your classic vehicle and using the latest API grade SM oil, you are almost certainly doing irreversible damage to your engine1. According to the SAE Tech Bulletin # 770087 2, operation of a flat tappet engine without adequate EP additives such as ZDDP quickly leads to lifter foot scuffing and cam lobe wear. Camshafts are typically only surface hardened leaving the core ductile for strength. According to the SAE Bulletin, once cam lobe wear reaches 0.0002ײ, “subsequent wear is usually rapid and catastrophic.” Two ten-thousandths of an inch is one fifth the thickness of an average human hair. In order to make engines last in the absence of ZDDP, virtually all IC (internal combustion) engines designed in the last ten years utilize roller lifters. Today, ZDDP has been removed from practically all automotive engine oils, rendering them unsuitable for use with older engines with non-roller lifters. ZddPlus + tm is the ONLY EP (Extreme Pressure) component which re-establishes the ZDDP levels that our classic car engines were designed for, while allowing the car owner to use the base oil of their choice. While some off-the-shelf additives may have some ZDDP, the amount per bottle is small, and when enough is used to get the proper concentration of ZDDP, there is a quart or more of unspecified oil that comes along with it. This dilution of 20% of your oil with an unspecified oil also means that there is 20% less of the proper additive package. The chart below compares the amount of ZDDP in ZddPlus + tm to GM EOS, an additive which claims to provide ZDDP based wear protection.
1 Anderson, William C., ‘New Oils and Old Cars’, Old Cars Weekly, 48 (2007-08-30) 2 Pless, Loren G., and Rodgers, John J., ‘Cam and Lifter Wear as Affected by Engine Oil ZDP Concentration and Type’, SAE pub 770087, 4 (1977)
David Navone
Navone Engineering, Inc. / ZddPlus
4119 Coronado Avenue, Suite 4
Stockton, CA 95204-2336
Cell Phone: 209-298-0454
Shop Phone: 209-465-6139
FAX 209-465-3059
email: dnavone@davidnavone.com
Web: www.zddplus.com
