Old 01-18-2008, 07:38 AM
jacb's Avatar
jacb jacb is offline
Send a message via Skype™ to jacb
Originally Posted by Jim Vander Wal
I mounted the shifter in the mid position. The shifter arm is about 6" long and almost straight up. This location puts the shifter about 8" back from the dash and in a comfortable position. I like it and have never wished I did anything different.
Jim
Thanks Jim
Just to make certain that I have got this correct ..... Did you use a spacer between your bellhousing and the engine (this tells me if you have a short input shaft) ..... if you do have a spacer then your transmission will be about 3/4" further back than mine will be .......... Ie if I dont use the spacer the shifter moves forward.
Did you purchased the "TKO mid position shifter kit" or simply reverse the standard shifter position? (no kit needed for the later).
