Old 01-18-2008, 12:36 PM
jacb's Avatar
jacb jacb is offline
Send a message via Skype™ to jacb
Originally Posted by Jim Vander Wal
No spacer between engine and bell housing.
Bought D&D's midshift kit. This is much like the Pro-5 shifter and the one that came with the TKO600. The D&D guys have been very good to work with.
I started with a McLeod and had problems with the starter alignment, dumped that beast and installed a Ford production aluminum, worked great. Then I saw the Quick Time scatter shield and installed that. An excellent and very cool product. Way lighter that the more normal scattershields and very well designed and built.
Jim
Hi Jim
Thanks again - I did'nt know about Quick Time http://www.quicktimeinc.com/products.html#ford ........ they look good so I have sent an email.
Regarding D&D - do they have a web site - cant find it!
Could you post a picture of your transmission tunnel .... Photbucket.com works well for pictures.
I am planing on using a McLeod RST 6913-07C clutch kit, what are you using? Which slave cylinder, T/O bearing and clutch fork have you used?
I know questions, questions!
Thanks again
James
