Old 09-04-2001, 04:28 PM
Smile
hi SCOTT I HAVE ERA 428, 427, WITH A 428CRANK IN IT IT HAS A TILTON STARTER IN IT I PAIDED 219.00 2 YEARS AGO CVR SELLS STARTER IN JEGS AND SUMMIT FOR 196.99 IT IS A NIPPONDENSO MOTOR WITH A 3:1 FOR 4:1 GEAR RATIO IT HAS 5 TO 18 ADJUSTMENTS TO SET THE CORRECT AIR GAP BETWEEN THE DRIVE AND THE FLYWHEEL THESE TWO PARTS STORES WILL GIVE YOU THE BEST PRICES MOST OF THE TIME. GIVE THEM A CALL AND ASK ? GOOD LUCK RICK LAKE RDCOBRA428@AOL.COM POWER IS YOUR FRIEND BUT TORQUE IS WHAT MAKES YOU MOVE.
