Old 01-19-2008, 03:30 PM
ERA2188 ERA2188 is offline
Cobra Make, Engine: ERA FIA; 331 stroker; TKO 600:3.54 Rear
My recommendation would be to go with a set of AFR 165 heads. They flow the same cubic ft as the Trick Flows and they do it with smaller valves = higher velocity and more power. They will bolt right on to the stock engine and go with the E cam or with the Trick Flow stage II cam. This combo along with an EDELBROCK performer rpm intake on a carbureted car will result in something like 350 - 365 hp. AFR will give you tech tips on springs etc. Also talk to Keith Craft - they can recommend a package - and they sell the AFR's. I jut put a KC 331 stroker in my cobra. Had a stock 302 in a previous cobra and went the TF route - because someone inadvertently said the AFR would not fit - their mistake and I went with the 'other' head. Good luck. Rickd
