Old 01-21-2008, 10:36 AM
jacb's Avatar
jacb jacb is offline
Send a message via Skype™ to jacb
Ward Brady Jr has kindly just sent the following:
"If you use a Quicktime bellhousing #RM6060 or #RM6065 (SFI approved w/block plate) then you don't need to change input shaft. The bellhousing is made for TKO to Ford 5.8. Use a ZA-125 fork, SC 124279 Slave Cylinder and a 614014 throw out bearing. You will have to make a bracket an D rod for slave.
Hope this helps and good luck.
Ward Brady Jr.
Snake Power Performance
1160 Goodrich Ave.
Glen Ellyn, IL 60137
630.348.2500 Office
630.348.2502 Fax"
ward@snakepowerperf.com
Now I dont want to appear slow Ward but who makes the:
ZA-125 fork
640014 T/O Bearing
Maybe this is basic USA stuff but I am trying to do this from England - ie get the part numbers and order the items.
Regarding the Quicktime bellhousings ....... long and short shaft versions seem to be the issue ........... so do I understand that with QuickTime bellhousings you never use a spacer, you just pick the bellhousing style that matches the TKO input shaft length? I suppose if you used a standard TKO input shaft and a short style QuickTime bellhousing, a spacer could save the day.
So why three styles? ...... SFI approved maybe? Flywheel size maybe??? Taken from the QuickTime website Quick Time Performance Products
RM-6060 5.0/5.8 Ford Bellhousing/TKO 500-600/TR3500/T5 Mustang transmission
• Height = 6.925
• Trans. Bore Ø = Universal 4.850/4.910
• Engine = Ford 289/302/351w/351c
• Trans. = Universal TKO 500-600/T5 Mustang/TR3550
• Clutch Ø = 10.5"
• Flywheel = 157 tooth
• Weight = 20#
• Universal shifter fork brackets for diaphragm or cable operated linkage
• Has passed all SFI testing
• Pivot ball, shifter fork brackets, full engine plate, and grade 8 bolts included
________________________________________
RM-6063 - 5.0/5.8 Ford Bellhousing/Ford Old Style Toploader/Borgwarner T-10
• Height = 6.112
• Trans. = Ford toploader/Borgwarner T-10
• Clutch Ø = 12"
• Weight = 20#
• Has passed all SFI testing .... Kim of Quicktime tells me that the bellhousing will be Certified within the next two weeks.
• Pivot ball, linkage bracket, full engine plate, and grade 8 bolts included
RM-6065 - 5.0/5.8 Ford Bellhousing/TKO/TR3550/T5 Mustang Transmission
• SFI Certified @ 6.1
• Height = 6.925
• Engine = Ford 289/302/351W/351C
• Trans. = Universal TKO/T5 Mustang/TR3550
• Clutch Ø = 10.5"
• Weight = 22#
• Pivot ball, linkage brackets, grade 8 bolts, and full engine plate included
What do users think about the large cutouts that the QuickTime bellhousings have for the clutch fork and starter gear. What about the grit gravel and road grime? Can you get covers or would you be better off using the heavy McLeod items (closed) on the road and leave the open style QuickTime bellhousings for the track?
