Brent, Ron, or Jamo,
I am running into an intermittent problem that seems to have no logical reason. Once in a while I start to change Forums or open a post and it will start the green status bars across the bottom like it always does but very slowly and when it gets to the 4th one it will just stop and go no farther no matter how long I wait. I have had this happen on Forum changes and trying to open posts and I never get a time out or error. I have tried both computers using different OSs and browsers, have cleaned all cookies, Temp. Int. files, History, and Prefetch files. In fact I tried to open this post to post this about 20 minutes ago and it did it and I went off line and turned the computer off and did some things then came back and decided to try and get on and it came right in. This started off and on right after you put the Nav. Bar in and then took it back out, but I have not heard anyone else say anything about a problem like this. And I have no problem with any other site, so it must be something that has to do with just CC. However it is so intermittent and happens when I am doing so many different things that I really don't know how to report it. As I said, no time outs no matter how long I let it set as I let it set for over 5 minutes once and all I had was the 4 green bars at the bottom and it said loading page whatever it was.
Edit To Add: Load seems to have no bearing on this as it has happened when there are many people on and when there were few on.
