Old 01-23-2008, 11:17 AM
patrickt patrickt is offline
Originally Posted by GreenSnakeDoc View Post
The flywheel specs are 28 Oz. external balance ... Trouble is its 13 1/4" O.D. where the old one is 14" O.D.
If you replace your externally balanced flywheel with a different sized flywheel (even though it is still externally balanced) you might encounter engine balance issues. Aside from the starter motor pinion issue, I would be very hesitant about changing my flywheel size on the balance issue alone.
