Old 01-25-2008, 03:56 AM
hogster hogster is offline
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Mine will run a single feed from the tank to an Impco E model evaporator, then out, splitting into two lines feeding the Impco 425's. They are both sitting on Holley 650 base plates, Edelbrock dual quad manifold (dual plane).
Had some issues with adapter plates to turn the Impco's sideways for the gas feed, and the base plates to fit Edelbrock, but looks nice now. The gas guy says there shouldn't be an issue with fuel supply, but if it starts to starve, I'll run a second evaporator.
I should be able to mount the evaporator within about 500mm of the mixers. I've just got to find some lpg graded, braided line to make up some fancy arsed fuel lines.
As for fuel economy, care factor, "ZERO"
Hogster
