Old 01-25-2008, 06:52 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
The number you gave couldn't be a head #, you have to have the manifold off to see the #. It's under the intake ports in area within the lifter valley.The fact that you indicated paint and seemed to say it was external means you were reading some other number...what I don't know because the date code is under the valve cover... the block number should be above the starter. I would ask again how you are certain it is an original Cobra engine? Ford sold loads of over the counter Cobra kits that went on 289s from Falcons to Galaxies.
WDZ
