Thread: Oil Leak
Old 01-26-2008, 10:59 AM
Virgil Virgil is offline
Initial thoughts when leak was first discovered were exactly as you suspect. Unfortunately, it's not the common causes like valve cover gaskets or the seal between the intake manifold and the block and heads. Performed the white paper towel test numerous times v/c gaskets and i/m are sealed well and dry. It is originating from the corner I earlier described. And, it continues from that area even when the car is not run from day to day. Wipe down dry and perfect, car sits, next day oil is back without ever running the motor.
