Thread: Oil Leak
Old 01-26-2008, 11:24 AM
patrickt patrickt is offline
Originally Posted by Virgil View Post
Performed the white paper towel test numerous times v/c gaskets and i/m are sealed well and dry. It is originating from the corner I earlier described. And, it continues from that area even when the car is not run from day to day. Wipe down dry and perfect, car sits, next day oil is back without ever running the motor.
OK, I got my fluorescent dye kit from AutoZone for about $20. It came with the dye, a UV flashlight, and some goggles. Put that in your oil and it should show you exactly where your oil is originating. Until I did that, I was fooled a couple of times by very thin trails that would then accumulate in a different place that was totally unrelated to the real leak. I had drips that appeared to be coming directly from the transmission and one small leak that looked like it was brake fluid coming out of the box that holds my brake master cylinders... except, the drips glowed in the dark when I added the dye to my oil. That's your next step.
