  #65 (permalink)
Old 01-28-2008, 12:49 PM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Brent,
Page 4 is displaying ok for me too. It was Page 5 that wasn't showing up when I made the posts and I was getting page 4 and no post as it was on Page 5 which never showed up until later on. That is what is strange. No one else seems to have this problem and mine worked the best it ever has until you put the Nav Bar in and took it out. I have had nothing but weird problems from all of my computers since and just on this site. I can go straight from here to my home page when I have one that hangs like the picture shows and go to any other site with no problem at all. Over in the test section Jon posted that he was having some strange problems but not exactly the same as I am in a thread I started called my problems. I was trying to duplicate something that would start them and couldn't. I have initalized my router, and modem several times. I now have the router disconnected and am just using the modem and one computer and still with the same problem. I just don't know how to explain it any better. I wish you could see it happen. When it stops like in the picture I can let it set all day and it stays that way and won't time out or anything and the Task Manager applications says it is loading a post. A few times it has loaded the post, went to a blank screen and then ran the status bars again as if it was loading the post over. But there will only be one post. It is almost as if two different things are trying to load or open the post at the same time at times. I very seldom have this problem early in the morning. Mostly from 11 O'clock on. This is driving me out of my mind as it only happens here and only after the Nav Bar episode.
Edit: Ok when I hit Submit for this post it just started and stopped. Then the screen went blank for just a quick second as if it was reloading and the post went in. Have you any suggestions. I have cleaned all files from the computers over and over, did the router and modem initializations several times, tried just one computer at a time, and still have the exact same problems. I even tried using System restore and setting this computer back to three days before the Nav Bar was first put in. Shortof formatting my hard drive and reloading, I don't know of anything else to do and since it works great on all of the other sites I can't believe it is something in my computer. Is there anything in the registry that would be dedicated just to a particular site like this? I have looked but can't find anything.
Edit # 2: Brent, this is a line from Steve Parks over in the Lounge. "Yea Ron, I have had the same problems. It seems the new equipment is not as good as well had hoped. I know Brent, Jamo and Ron are working their butt off to get all the bugs out, but this site is really hard to navigate around in right now."
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
