Thread: Steering Column
Old 01-31-2008, 04:02 AM
Rob. Smith Rob. Smith is offline
I've got an RMC with a sigma column. .. I have totally rebuilt the thing to put the ignition switch behind the dash and pull the steering wheel closer to the dash board. I also made the outer tube and mounting brackets out of stainless. These columns are the most basic design you can get. you probably could build one from scratch.
The Booster is also an "easy-out". It happens to fit a ford master cylinder...! Go to a decent brake mob and they can sell you anything you want. I have just helped another cobra owner put a better booster in his DRB. It was the same can as the sigma but with a different drilled mounting stud pattern....they are a "universal" unit and there's a million combinations out there ! Good Luck !
