Old 01-31-2008, 06:53 AM
patrickt patrickt is offline
Originally Posted by RICK LAKE View Post
I don't agree with Pat on the oil pressure at idle...
That's what makes this forum fun.
Go to the FE forum and ask...
... and you might find this post on oil pressure at 332-428 Ford FE Engine Forum
The Ford shop manual 1970 (has Boss 02/429/428cj/scj/429cj/scj) great ref. materia ... correct psi is 25-60 lbs @2000rpm HOT...minimun psi is 6lbs at 400 rpm , lifter collapse, valve train noise. Bearing clearances of .0025/.003 will result in 10-15 lbs at hot idle, and 65lbs at 2000...
