Old 01-31-2008, 10:01 PM
Power Surge's Avatar
Power Surge Power Surge is offline
Originally Posted by jwd View Post
I believe the problem that was in the link above stemmed from the shift lug slipping on the rail or something like that. Probably from being pulled out of gear with torque on the gears. I've rebuilt many trans. but never had a TKO apart so I'm not sure how their shift rails are set up. I've never had a problem with mine or know of anyone personally that has. The internet makes any problem seem more common than it actually is because the one's having the problem are very vocal. If everyone that never had a problem with a TKO posted it on every forum, the internet would be flooded with happy TKO owners.
Regardless, the problem with the original poster is the clutch.
You're right. I was thinking ahead as I was reading, before even finishing his post. Clutch is it for sure.
I did a POS Spec clutch in an 03 Mustang a while back, and the car did the same thing. Had to shut it off to get it into gear. Wouldn't go in reverse or 1st running. The clutch was actually warped (brand new) and never fully released.
Sal Mennella
