Old 02-01-2008, 10:46 AM
Joe Wicked's Avatar
Joe Wicked Joe Wicked is offline
The TV will work. That is not the problem. The picture may not be as good as you are used to seeing on the TV. If you are OK with that, then you are golden. Netflix may also only download a lower quality video because of the bandwidth that the higher quality requires. I do not know. I would say hook the laptop up, pop a dvd in and see how it looks. If it is similar to the dvd player, then your graphics are good enough. If you do not like how it looks at all, then you know. The standard analog PC cable (blue) is pretty cheap. If you were local to me, I would give you one. I have 1 or 2 that I am not using.
