Old 02-02-2008, 06:00 AM
blykins blykins is offline
Theoretically, a .050" head gasket should give you a good .040" quench and just as long as your piston/valve clearance is good and compression ratios are still good, it should work.
However, I wouldn't do it that way. I would take the pistons and have .010" milled off the top to get the pistons to a zero deck scenario and then go from there.
