Thread: VDO Tacho
Old 02-02-2008, 03:33 PM
sideshow sideshow is offline
hey dimi
on the ford ecus there is no external wiring thats goes to the tacho alone
its done by serial data
you can try an adapter that runs off the crank or cam sensors
u just have to be careful u dont disrupt one of these signals or engine might start missing at hi revs or something similar
another thing ive heard can be done is remove ecu covers and on the circuit board there is a pin or track that has rpm signal but this might be risky
ive heard it being done never seen it
easiest way is to hook up tacho booster from cam signal but first i would have to see how many triggers are on each
as i think the crank signal is way to many pulses and its prbably not perfect as it has a missing tooth pulse
so cam sensor might be the go
or run a 4 into 1 tacho booster off 4 coils then it has 1 output
my website
www.sideshowsperformancewiring.com.au
