Old 02-03-2008, 09:36 AM
SPF1061's Avatar
SPF1061 SPF1061 is offline
Cobra Make, Engine: Superformance Mk III / Windsor platform
Dan -
You didn't ask me, but I'll chime in. I have the Olthoff mounts on 1061. They
are the solution to your problem, not shims. If you are producing enough torque to hit the body, you MAY be able to shim the engine into a position that the pipes no longer hit, but eventually the rear side pipe mounting brackets will break from the stress created by the flexing.
steve
1061
