Old 02-03-2008, 01:55 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
You first manually put the toploader gears all into neutral, they should "click" into place. You then manually move the shifter throw arms, underneath, so they are in a middle position such that ther is a notch in the side of the shifter housing that you are able to put a alignment drill bit/bolt, to align the shifter arms in neutral position, (like what you have said you have already done, and then you manually adjust the shifter ends of the rods to fit the length between the shifter arms on the tranny and the shifter arms underneath the shifter.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
