Old 02-03-2008, 04:35 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
The other thing to check is the length of the cable end that fits into the speedo. If it is longer than the one on your old cable, it could be bottoming out in the speedo which will prevent it from turning freely. I had a similar problem with my autometer speedometer- I just put a couple small washers around the cable end to shim it out from the speedo a little bit and the problem was solved.
Replica is not a dirty word.
