Old 02-04-2008, 11:00 PM
Keithc8 Keithc8 is offline
As mentioned above this is pretty common on the 1969 block because the deck height is about .030 less than the 1972 and later blocks. You can run a thicker head gasket or cut the top of the piston .010 and both should work just fine. The graphite gasket that Ford Racing sells is about .050 compressed and would work fine for you. Good luck, Keith
Keith C
