Old 02-06-2008, 07:28 PM
63mercury's Avatar
63mercury 63mercury is offline
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
I had them custom made to my specs and they are just a light press fit so they can be removed for final fitting before welding permantly. I think I can send you my wrawing for them if your interested, dimensions can be adjusted to your tubing id. The hardest part was finding a 5/8- 18 LH tap without spending a fortune.
My heim joints are better grade from Speedway Motors with no grease fittings, might have to change that later but time will tell. Carl
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
