Old 02-07-2008, 02:47 AM
sambo's Avatar
sambo sambo is offline
Originally Posted by macloft View Post
Hi Sambo
Warrick sells the splined connecting shaft and appropriate bottom uni the top one I used is the laser. As Darrell said use a flat blade driver to open the uni up to fit the shaft. I only have two unis one on the end of the laser column and one connecting to the steering rack. Will you have a uni in the middle to?
My connecting shaft is 16mm dia. I would lathe down your 3/4 stainless rod at the steering column end and spline it to fit the laser uni.
G'day Bruce. I think because I went with the VK power rack Warwick wasn't able to supply the lower uni. The Laser uni fits fine, no screw driver needed. Ideally I would like to machine the end of the column if it's physically possible and so long as it doesn't overheat the bearings. Then I've got new, serviceable u-joints and 3/4" all the way from the top uni to the rack.
And yes I have the same setup as you: steering column, uni, connecting shaft, uni, rack.
