Old 02-07-2008, 03:57 PM
63mercury's Avatar
63mercury 63mercury is offline
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
I posted some incomplete info on my last post, the bushings on the front are taped 5/8-18 RH and for my entire suspension(4 link with panhard bar) needed 9 bushings with RH threads and 5 with the LH threads and if the upper arms are also made add 4 more of each making a total of 13 RH and 9 LH for this type suspension. I hope this clears up my mistaken info posted before. Also if the pre welded upper ball joint piece is used that will require 2 RH and 2 LH 1/2-20 bushings. Carl
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
