  #25 (permalink)
Old 02-07-2008, 06:08 PM
Power Surge's Avatar
Power Surge Power Surge is offline
Originally Posted by cobred View Post
Sal, why cant you use a pcv with the oil fill tube? I have the Blue Thunder with the fill tube and breather in front. In the back I have the pcv adaptor with the vacuum hose into the base of the carb. Seems to work fine so far. Any reason this is no good?
It won't work as it's supposed to, because you're taking in outside air. A PCV system should be a closed crankcase.
Sal Mennella
