  #32 (permalink)
Old 02-07-2008, 06:13 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
[quote=Power Surge;
If you use the fill tube, you can't have a PCV. If you use the plug, you can have a PCV. You can run a PCV two ways... either coming off the valve cover and going to the intake/carb (to be injested into the engine) or off the back of the intake and to the intake/carb.[/QUOTE]
Sal, why not? I have the Blue Thunder with the fill tube and breather in front.In the back I have the pcv adaptor with the vacuum hose into the base of the carb. Seems to work fine so far. Any reason this is no good?
