Old 02-08-2008, 04:32 AM
Default A turbo or blower on the car
wycobra Have you thought about a small blower or turbo for the 351. Dollar for dollar this may be the cheapest way to get the power you want at 10,000 ft. where the air is thin. Paxton or vortech both have easy kits to install. The adjustments will be for either carb or FI system. If you are running FI the injectors need to be bigger and the fuel pumps needs to be a min of 255lrs. with #8 fuel line to the injector rails. You would need exhaust work with turbos or turbo. The blower would be the simplest to install. Check height between the blower hat and the hood if carbed. FI should be no problem. Good luck Rick L.
