Old 02-08-2008, 06:54 AM
bobcowan's Avatar
bobcowan bobcowan is offline
It's not much differant than a low altitude build. You just want to increase your effective cylinder pressures a bit.
With a moderate cam, you can easily run 10:1 static. With a radical cam, 11:1 isn't a problem, either. I run 10.8 with a big cam. Unless it's really hot, I run mid grade pump gas without any problems.
