  #122 (permalink)
Old 02-08-2008, 08:00 AM
Don Don is offline
Ron/Brent:
On an intermittent basis with no obvious pattern on the CC site and other web sites, with the Block Pop-Up Windows option turned on , using Apple Safari , appears to influence the access and performance. Will shut off, all OK. At other times will have the option turned on for the same web site, and no problems.
In my case, appears the Apple Safari software creates the situation. Have you tried turning off temporarily when using the CC site any options & preferences that could possibly contribute to your situation. Now, when having access problems on any web site, my first choice is to turn the Block Pop-Up Windows option off, high success rate.
I do not use Firefox on a regular basis as the primary, do not know whether the pattern mentioned would be duplicated. Apple software 10.4 version is current. When I upgrade to OS X 10.5 Leopard, will see if the same situation exists.
