Old 02-09-2008, 10:22 AM
tcrist tcrist is offline
DV, Thanks for the input. I know that you know a lot about CR'S. My issue is with the cable adjusted with no pressure on the throwout bearing there is not enough throw on the clutch pedal to engauge the clutch. My car is a CR LTD built demo car and the clutch cable is the origional one. Why it doesn't work correctly (or at least the way that I think it should), I don't know. capeddie says his has worked this way and he has never had a throwout bearing issue. You will have a PM shortly.
Thanks, Terry
