Old 02-09-2008, 05:13 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Ed,
May I assume you two have the same kind of Cobra and Clutch set up? If so can you describe the cable for me? Does it have a large white heavy plastic plug on the end that goes into the firewall and is the other end a threaded rod? If so do you have a "barrell" of sorts that goes through the firewall and does it stick out from the firewall about 5"s with the cable going through to the clutch pedal. Geesh, I just trealized you said you are using an automatic! Oh well, trcist, these are the first questions I am going to ask you too.
DV
