Old 02-09-2008, 10:48 PM
HI Cobra's Avatar
HI Cobra HI Cobra is offline
Terry,
I just checked again and the piece that is attached to the bell housing is
identical to yours. Looks like the threaded rod that goes through the
take out arm is the same too - it has two 1/2" nuts for adjustment and yours
in the picture looks like it has about the same adjustment in the threads as
mine. My cable extends forward past the front header pipe before it turns
back to the firewall. The pedal linkage in your picture also looks like mine.
I can only guess that your pressure/plate clutch may be different but it
would seem the throughout shouldn't be that different what ever is used.
My plastic fitting in the bell housing isn't as clean as yours but when I got
underneath with a mirror it is the same (only dirty). Not sure what is
causing your problems. I was a little nervous at first with the cable set up
thinking I would be adjusting it frequently but that hasn't been the case.
I don't track it (hey, this is Hawaii, no more track) but I have been known
to get on it now and then. Having said this it will probably break.
Flip
