Old 02-10-2008, 11:45 AM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Even if you find a problem with alignment as Rick suggested, spend the the extra $12 for the high temp fluid! If you find the alignment is good, try the fluid first.
Why would all the other aluminum master, and slave cylinders, in all the other cars here, work without turning the fluid black, and yours doesn't?
