Old 02-10-2008, 07:58 PM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Default From your other suspension post
This may be to simple but have you considered just removing one third to one half of one coil? This should lower your ride height while changing your spring rate very little and can be done with an abrasive wheel or the venerable “flame wrench.” Just in case you're wondering; it will raise the rate slightly but you shouldn't have the rubbing issues associated with the lower rate springs. As far as what it will do to your handling; well, with the lowered ride height and minutely raised rate I doubt there will be much of a change at all. If anything it will probably more favor over-steer but I'd give that a shot first before buying new springs. JMHO
Steve
