  #24 (permalink)
Old 02-11-2008, 08:41 PM
mtpockets's Avatar
mtpockets mtpockets is offline
Cobra Make, Engine: BDR #621, Keith Craft 408
Default Jets, linkage and cam
Here are the jets used. Again, this is one of Keith Crafts "Econo" 408w crate motors. I asked him to make a recommendation of whether is "Standard" or "Econo" would work better with the Webers. He recommended the Econo with a different cam. I bought the complete Weber set up from a fellow Hot Rodder here in the Houston area. He had a 408w built and had ordered the carbs to fit that motor. Weber setup had never been used.
Jets:
37mm chokes, 160 mains, 200 air correctors, 60 idles, 120 holders, 55 by passes, and F7 emulsion tubes.
Linkage:
The linkage is custom and was designed by Chuck Kendall (AKA Traindriver) on CC. I installed the throttle cable and hooked up all the linkage tonight. Very nice setup. Installed two springs on the linkage (pass tech inspection) and a spring return on the pedal (just because).
Cam:
Off the KC build sheet: Item#: 35-426-8 Comp Cam. Cam specs: 555/576 288/294 236/242 @ /.050
"Friends don't let friends apex early"
TCC President 2010
