Thread: msd 6al 6420
Old 02-12-2008, 05:57 AM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Originally Posted by Scufty View Post
ok Im crap at electrical but here goes...I pull the car into the garage all good...push it out to do some cleaning. Try to pull it back in ..no go. getting fuel, poor or no spark.
How did you test for spark? I use the old screwdriver in the coil wire test (not touching the SD or coil wire) with the SD propped on the intake or VC a good MSD box should jump a 1/2" gap no prob.
I seem to have power to the MSD box no power leaving to coil from what I can tell.
How much power to the MSD Box? As Greg said it must be good high amp power for the thing to operate properly. Is the box making any noise?
test orange and black at coil ...notta
is there a way to tell if you have a pooched msd box?
You might want to check this link and poke around on that forum to see what you can pick up.
MSD 6AL Suddenly dies - MSD Ignition Tech Support Forums
Hope that helps, Steve
